MSI upgrade leaves version in Add/Remove Programs List
amolago
Post by amolago »
Our IA project produces the Wrapper MSI for users to install. Once run (msiexec /i product_1.0.msi), there are several registry entries produced:
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{PRODUCT-CODE} (DisplayVersion=1.0.0)
HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{PRODUCT-CODE}
HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{WRAPPER-MSI-V1-PRODUCT-CODE} (DisplayVersion=1.0.0)
HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall\My Product (DisplayVersion=1.0.0)
In Add/Remove Programs we see:
Publisher: Us
Version: 1.0.0
All good with that, but now I run v2 (msiexec /i product_2.0.msi), which contains the code
  if Variable NEEDSUPGRADE Equals TRUE
    Install/Remove MSI Package $PRODUCTCODE$[REMOVE=ALL] (get result into variable REMOVEOLD)
Which removes the old version, and installs the new version without issue. The only niggle now is the registry and two entries in the Add/Remove Programs:
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{PRODUCT-CODE} (DisplayVersion=2.0.0)
HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{WRAPPER-MSI-V2-PRODUCT-CODE} (DisplayVersion=2.0.0)
HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall\My Product (DisplayVersion=2.0.0)
Publisher: Us
Version: 1.0.0
Publisher: Us
Version: 2.0.0
It seems there is no way of getting hold of the MSI wrapper product code without implementing some kind of registry search for old versions as part of the remove old code. I had the idea that I can interrogate the created MSI and find its product ID, then modify it to pass that value to the real setup and then store that value in the registry. I can then use that value as part of the remove old code.
Before I go implementing all kind of things to find the MSI product code, is there a better solution?
JohnGaver
Re: MSI upgrade leaves version in Add/Remove Programs List
Post by JohnGaver »
Sounds like you're on the right track!
This page refers to the $GPOPATH$ variable, which might be helpful for you during your interrogations:
https://www.installaware.com/mh52/deskt ... wizard.htm
BTW, was there a reason you used the MSI wrapper for all your users at large? The main scenario it is intended to address is Group Policy Deployment, for which it works very well.
If you could let us know more about your particular scenario, we could possibly upgrade the plumbing for you here moving forward.
John Gaver
InstallAware Skunkworks
