I wonder if it is possible to automate the Product Version parameter of the project, when running the buid automatically using miabuild.
When the product version changes (this is for example parameter of the automatic build procedure), I would like to update the Product Version parameter of the IA project.
What would be the recomended way to do this?
Andrej
Automatic Product Version update
Hello Andrej,
I'm afraid you cannot change the version number itself from miabuild - you will need to use the automation interface, or just edit the plain text MPR file to make this change.
Of course, you can easily generate a new revision code every time you do a build using miabuild.
