When uninstalling a web site that has been installed using
Create IIS Site "$SITENAME$"
Get IIS Index for Site "$SITENAME$" into SITEINDEX
Create Virtual Folder "" in IIS Site #$SITEINDEX$, pointing to physical location $TARGETDIR$\\web
only the Virtual Folder is removed. The web site is left causing the site to report errors when starting IIS Manager. Version is 6.0.
Regards,
-Manso
Uninstalling web site
You need to add the appropriate uninstall commands before Apply Uninstall in your script. The visual IIS Sites view automatically emits this code for you, you can create a dummy site and see the kind of code it creates.
