Remove Modify on Maintenenance
hsmith
Post by hsmith »
I want my installer to only offer repair and remove when doing maintenance, and to hide the modify available options. Is there an easy way to accomplish this?
Howard Smith
seanmckenna
Post by seanmckenna »
In the dialog editor for that dialog, you can just the the enabled property to false for that radio button. This way it won't show up. This is real easy.
You can also just delete those controls permanently, or hide them. You can customize every aspect of your dialogs in InstallAware!
hsmith
Post by hsmith »
Thanks guys, I had already thought about this, but I just wondered if there was a more 'formal' way to acomlish this,
Cheers
Howard
