Error installing InstallAware Plug-ins
I cannot install the Import MSI Database Plug-in, every time I download a fresh copy it says the download web data is corrupt. I am downloading it through the InstallAware installer. I have InstallAware Studio Admin 6. Actually none of the plug-ins will install correctly.
Please disable all firewalls and other network security software, which may be interfering with your download. Then try again.
You may also try to use the single file installer if you cannot get it to work this way. Be sure to uninstall your existing copy first, before running the single file installer.
