Minor InstallAware Update
A minor update (6.03) is available for InstallAware. This version adds the following new functionality:
  • 1) URL Lists for Web Media Blocks: You may now specify a full list of URLs for your web media blocks. If a download fails or is unavailable at one location, it will be retried at other locations, before an error is raised.
    2) Individual Passwords for Web Media Blocks: When doing encrypted builds, you may specify individual passwords for each web media block. This lets you use different passwords for the master setup and web media blocks.
    3) Native Evaluate Expression command: You may use the Eval plug-in, or this newly built-in command to evaluate complex expressions. The syntax of Evaluate Expression is identical to Eval.
Upgrading instructions:
  • * If you are a licensed user, just re-generate your license and re-install it. You do not need to install the full product again (unless you wish to update your help file, which contains documentation for the new features above).
    * If you are a trial user, just re-download and re-run the trial setup from the public website. This will upgrade you to the latest version.
