In the visual view, It seems that you can't control the title that gets listed in Add/Remove Programs. Mine seems to end up using the Product Name.
I would rather have it be <CompanyName> <ProductName> <Version>. Is it possible to change this, or is it always using just product name?
Add/Remove Programs Listing
seanmckenna
seanmckenna
Windows Installer internally calculates the size - tends to go wild with a lot of repeated install/uninstalls on the same machine. You can write to a registry key to record your own custom size (there should be other posts on the forum about that).
The product name that goes into ARP is always the value of $TITLE$.
