I just want to be sure I understand the Patch feature properly (I'm not much of a Windows Installer guy.)
In the IDE in the Patches view, I add references to 2 prior versions of my product, say version 1 and version 2. My intent is to update all users to version 3. If I hit Build Patch, one EXE is produced. So can I assume that the new EXE contains all the info required to update both version 1 and version 2 users? And how is the patch applied to version 1 users? Is it done under the covers in 2 steps, i.e. 1 -> 2 -> 3, or is it one step to go from 1 -> 3?
Patching multiple vesions
It'll update both old versions in a single step. 1 goes to 3 directly.
Yes, you should - full setups are required.
No, this is not possible. What you can do though is use the (Un)Install MSI Setup command to (optionally silently) uninstall them as part of your setup pre-requisites before you start your main install routine.
Users browsing this forum: No registered users and 194 guests
