Hi As i m evaluating IA i had come across few issues:
Is it possible to change the content (caption) of Static Label or Text at Runtime
If i had added Label control from standard tab ,i can set caption at design time but i wanted to change the information at run time. I checked in object behaviour only perform action is enabled and this label cannot be associated with any varialbe so that if value of variable changes caption of label should also change.
secondly if i choose static text control from Additional controls available in toolbar then it can receive information from a list of varialbes like Installation Progress,component Description,component req space etc which is not my req i need to display data at run time with respect to information available in my configuration file in some key
Changing Text of Static Label/Static Text control Runtime
rajeshjeet
