Project corrupted?
Paul
Project corrupted?
Post by Paul »
1. When I run my project I get the following message: Unable to load plug-in library. Please rebuild your project and make sure all required plug-ins are installed. Action skipped.
2. When I debug my project when I put break point on one line it stops at wrong line. While debugging and stepping through the code the highlighter is positioned at wrong lines and when finished I get the following message: Runtime error in setup script: Line 463: List index out of bounds (462).
The line 463 does not exist. My last line number is 363.
Please help.
Thank you.
Pawel
Be sure to rebuild your project, and try it that way. Also remember that Include Scripts do grow your script. If your project is corrupted completely, try to restore it from the .MIA.BAK file that will have been the last saved copy - hopefully that is of some help to you.
