convert xp msi to vista-compatible msi
Is it possible to convert an XP .msi to a vista-compatible .msi with InstallAware? Thanks for any info!
Yes, any setup you create, or capture/import and re-create in InstallAware will be automatically Vista compliant.
how exactly?
hi, thanks for the response. I imported the .msi and am wondering what to do afterwards? Which command will recompile it? I keep getting an error message saying it can't assemble something when I tried the build command. thanks -
I think you will find it easier to use PackageAware - please give that one a try instead!
Users browsing this forum: Google Adsense [Bot] and 33 guests
