Create IIS Site
Create IIS Site
when i use the command Create IIS Site "Site name" it creats a new web site but this site does not contain a directory path. how can i add a directory path to the IIS site i create ?
Use the Create Virtual Folder command to create the "root" virtual folder on the new IIS site. You can use the visual IIS Sites view to have the IDE create the necessary setup commands for you visually.
