I am using InstallAware to build setups on a build machine, using the commandline build tool. I am in the process of setting up another build server, to replace an older one. I was able to install InstallAware, Studio edition, but when I run my licensing program, I get an error message saying "InstallAware cannot be located on your system".
I have installed (and licensed) this on one other build machine, and my dev machine without any problems.
When I installed, I only selected commandline build, since this is all I need on this machine. Does anyone know why I'm getting this and what to do about it? Thanks.
-Sean
License Installation Problem
Install the basic plug-ins that you will need - that will help the licensing tool find the product. You need the plug-ins for successful builds anyways.
Users browsing this forum: No registered users and 46 guests
