I have a custom text entry field that requests a Network Share value from the user. The expected format is something like:
\\\\ServerName\\Share
I am capturing the value entered into a variable; however both of the \\\\ characters are not being retained. Only one \\ come through in the variable.
If I enter the value as:
\\\\\\ServerName\\Share (prepending \\\\\\ in the field)
then I get the expected value of:
So my question is: how do I maintain both the \\\\ characters at the beginning of the text entry without making the user enter \\\\\\?
Any help is appreciated.
Capturing \\\\ as entered on custom dialog
Can you show a MessageBox right after the dialog returns and see what you get? Some commands will eliminate \\\\ into \\ as a convenience when using paths, and I think this might be what you're running into - but the elimination is smart enough to respect UNC paths.
The InstallAware Web Update script uses a text control and accepts input in this form: \\\\server\\username. That works fine, which is why I asked you to confirm right after showing your dialog with a MessageBox.
It has the correct value in a message box immediately after the dialog. When I try to use that value as a parameter on a "Run Program" command, the value does not contain both \\\\.
What do I need to do to have InstallAware maintain both \\\\ characters so that the full and correct network share will be contained in the variable value?
I see, so Run Program is losing it. I would add \\\\ in front of the variable to make sure it doesn't lose it. So if the variable in the dialog is called $VAR$, use it in Run Program as \\\\$VAR$.
Users browsing this forum: No registered users and 47 guests
