Hi!
Is it possible to include the value of a variable in the output filename?
The install file now is always named like the project, but we would like to have the version number encoded into the setup file without always having to rename the project or manually change the output filename.
regards,
Mike
Output filename with variable?
Mike,
use a compiler variable to hold your version number. A compiler variable is created in Project/Options... (CTRL+SHIFT+F11).
Then go to build settings and set an output filename based on your compiler variable.
Example: projectname#VERSION#
Martin Rothschink
AxoNet Software GmbH
Compiler variables are substituted at build time, whereas variables change value while the script is running. Please see help for more details.
Users browsing this forum: No registered users and 55 guests
