How to avoid that support files arecopied to project folder?
binkle
Post by binkle »
I wonder why these files are copied into the project folder.
There should be an option for just linking them.
Files like the icon, readme or EULA should not be copied.
EULA and reame e.g. may change on each version, so I have to manually copy them into the IA project folder now. This makes no sense.
As they belong to my software project these files should be only linked into the IA project, not copied.
Greetings
Harry
binkle
Post by binkle »
Helloo,
does any know how to do this?
andrejzr
Post by andrejzr »
Hi Harry,
You can achieve this by manually editing the mpr file, and instead of just the name of the support file, you can enter relative path to the support file. This is working fine for me, but be aware, that this is something I tried on my own - relative paths are not officially supported.
IA team - please correct me if I am wrong.
Andrej
