IDE compiler <--> miabuild.exe different setup behavior
binkle
Postby binkle » Fri Sep 29, 2006 8:20 am
when I complie my IA project using the commendline complier (miabuild) I get a different setup behavior in opposite to compiling with the IDE.
Why can this be?
Postby MichaelNesmith » Fri Sep 29, 2006 12:51 pm
Are you specifying the same values for compiler variables as in the IDE?
binkle
Postby binkle » Sun Oct 01, 2006 2:53 pm
Yes I do,
I use only one variable, a path variable, which is the same, otherwise it would not find the files.
More specific:
When I compile with the IDE and start this setup on a Pc where the same version is already installed it tells me I have to deinstall the privious version and starts to deinstall it. But it shows the form (step) for installing. After this the next step shows the same form but now it installs.
Using the commandline build on the same PC it first deinstalls the existing version with the correct forms then finishes. Then I have to start setup again to invoke the install. This time a "run ... as" command at the end of the setup does fail every time.
This command does not fail when the setup was compiled with the IDE.
I can sent you both setups (each 4MB, or give a download link), if you like to. But you need to run them on a windows server with exchange to see the exfect of the "Run ... as" command.
Tinus
Postby Tinus » Mon Oct 02, 2006 2:38 am
Harald,
have you used the /r parameter to create a new revision code for your command line build?
If not - please give it a try.
Martin Rothschink
AxoNet Software GmbH
binkle
Postby binkle » Wed Oct 04, 2006 2:59 am
Great,
that works...
Thank you
Users browsing this forum: No registered users and 39 guests
