Install Jet-Engine
KaBa
Install Jet-Engine
Post by KaBa »
I need to install the Microsoft Jet Engine 4.0 for any of my apps. I dont find a merge module or application runtime in installaware. How can I install the jet engine with your programm.
Im try installshield and this programm has a merge module...
Karsten Baumann
Post by CandiceJones »
If you already have a merge module for it, just add it to your project in the Deployment | Merge Modules visual view in the IDE. Then rebuild your setup and you're all set.
KaBa
Post by KaBa »
I think its not allowed to use a installshield-merge module with other deployment-applications. You are plan to add new merge-modules such as JET-Engine to installaware? Can I convert a merge-module to a web media block?
Karsten Baumann
Hi Karsten,
Microsoft probably has free merge modules, or even MSI/EXE installers that you can use with the (Un)Install MSI Setup/Run Program commands, to install the JET runtime. Just do a Google search and this will reveal the results you want.
And yes, you may also convert an existing merge module into an InstallAware setup project. Just run the Database Import Wizard to make this happen and it will create a script for you that you can just copy-paste into your existing script.
Whichever way you want to do it is fine - a lot of ways to achieve your objective, pick the one that is easiest/best for your needs!
