Comparing file versions
khalprin
Post by khalprin »
I would like to stop an existing installed service only if the install program is going to update it with a newer version. I looked at the Check File Version which can compare versions of two files. To use that, do I need to put my service file in the files list and in the support files list so it is available for comparison, or can I compare right from the DATADIR folder? Is there a better way to do this?
Well, you could compare directly with a built-in version number. If you want to auto-compare without hard-coding a version number, then I recommend the $SUPPORTDIR$ approach.
