Execute setup.exe via msi
Erdnuckl
Post by Erdnuckl »
Hi!
I'm totaly new to scripting msi pakages with InstallAware. So here is my question: I need to execute a setup.exe with commandline options via a msi. Is this possible?
The matter why I need this way is the Adobe Creative Suite. Capture and repackingen is not working and Adobe provide a way for silent installations. But you can only deploy msi packages via GPO in Windows and I want the CS2 installed automatically without any user interaction.
Thank you.
Best regards
Erdnuckl
Yes, you can certainly do this. Just use the Run Program command to run your MSI in your MSIcode script.
