I have a setup that has been localized into english and italian. After the initial set of strings were translated, I had to add a couple. So I reran the localization wizard, and told it to update the existing files. Now, after I open the mTranslator Utility and make a modification to any of the strings, I get a List Index Out Of Bounds (0) error.
I'm also having a real big problem with the fact that all of the variables are stored in the localization files. If I have to change a value of one of my If statements, it appears that I have to go into the mTranslator Utility and modify all of the insances of it. (then I run into the List index issue again)
Suggestions?
Please Help!!!
P.S. Using IA 5.31
Issue with Updating localized strings
Hi Joel,
A few MSIcode commands had problematic localization in 5.31. This has been fixed in 6.0. You should not receive any errors of the kind with the latest version.
Apologies for the inconvenience.
Users browsing this forum: No registered users and 34 guests
