How can I identify the exact line of an error message? If I build my installer in the IDE, it runs properly on my VMWare test machine. If I build it from my FinalBuilder script, then it is failing with an error message:
Runtime error in setup script:
Line 74: List index out of bounds (73)
Now, this is quite interesting because I've been looking at the script and commenting a few lines out, and the error initially was on line 64 with a 63 in parenthesis. Anyway, I only include the msi20 install scripts, but can't work out why it might be failing at all. I tried an uncompressed install in the hope I might be able to see the text, but that didn't work.
I've tried turning on logging, but it obviously fails before that starts.
This is a script that has been in use for a while, but now stopped working. I just upgraded to 6.03 due to another issue I thought maybe fixed.
I've spent a few hours trying to work out why this might be happening, but can't. Is there anything changed in 6.03 that might be causing this behaviour? I wondered if a dialog might be the cause.
Matthew
