MSI (s) (30!E4) [01:31:13:562]: PROPERTY CHANGE: Adding SHORTCUTFILES property. Its value is 'C:\\Documents and Settings\\aaa\\???????\\???\\'.
Action start 1:31:19: CostFinalize.
MSI (s) (30:94) [01:31:19:500]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI (s) (30:94) [01:31:19:546]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI (s) (30:94) [01:31:19:593]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI (s) (30:94) [01:31:19:625]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI (s) (30:94) [01:31:19:671]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI (s) (30:94) [01:31:19:718]: Note: 1: 2262 2: Condition 3: -2147287038
MSI (s) (30:94) [01:31:19:765]: PROPERTY CHANGE: Modifying TARGETDIR property. Its current value is 'C:\\Program Files\\OurProduct'. Its new value: 'C:\\Program Files\\OurProduct\\'.
MSI (s) (30:94) [01:31:19:796]: PROPERTY CHANGE: Adding PDFHOTCTFLDRDCIIOEXLOERELPLNKTF0_1 property. Its value is 'C:\\Program Files\\OurProduct\\'.
MSI (s) (30:94) [01:31:19:843]: PROPERTY CHANGE: Adding PDFHOTCTFLDRDCIIOEXLOERUTRILLKT0_1 property. Its value is 'C:\\Program Files\\OurProduct\\'.
MSI (s) (30:94) [01:31:19:921]: PROPERTY CHANGE: Adding PDFSHORTCUTFOLDERREADMELNKTF0_1 property. Its value is 'C:\\Program Files\\OurProduct\\'.
MSI (s) (30:94) [01:31:19:968]: PROPERTY CHANGE: Adding PDFHOTCUTFOLDERXRAY99MODELLNKTF0_1 property. Its value is 'C:\\Program Files\\OurProduct\\'.
MSI (s) (30:94) [01:31:20:000]: Note: 1: 1324 2: ??????? 3: 1
MSI (s) (30:94) [01:31:20:046]: Note: 1: 2205 2: 3: Error
MSI (s) (30:94) [01:31:20:078]: Note: 1: 2228 2: 3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1324
Error 1324. The folder path '???????' contains an invalid character.
MSI (s) (30:94) [01:31:27:687]: Note: 1: 2205 2: 3: Error
MSI (s) (30:94) [01:31:27:734]: Note: 1: 2228 2: 3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1709
MSI (s) (30:94) [01:31:27:796]: Product: [OurProductSnipped] -- Error 1324. The folder path '???????' contains an invalid character.
Action ended 1:31:27: CostFinalize. Return value 3.
Action ended 1:31:27: INSTALL. Return value 3.
Any thoughts or workarounds would be welcome for this. Thanks,
Matthew
