Lowercase in Web-Project
KaBa
Postby KaBa » Wed Oct 18, 2006 6:17 am
Hello NG,
my project is a web-based-exe with any web-blocks. Now I have a problem with the names. In my Project the blocks has names such as "Microsoft Windows Installer 2.0.7zip". When I build the web-exe, InstallAware use only lowercase. The web block is called after the build "microsoft windows installer 2.0.7zip".
When I start the setup from web, the installer dont find the block with the lowercase-name.
What can I do, that InstallAware use my original-names???
Karsten Baumann
Postby MichaelNesmith » Wed Oct 18, 2006 8:39 am
Hi Karsten,
Are you using a case sensitive Linux server? In that case, please rename the files. Otherwise, the file case does not matter.
KaBa
Postby KaBa » Wed Oct 18, 2006 9:47 am
I host my files by Strato.de and there the setup dont run correct...
Karsten
PS:
I wrote a little App, wich rename my files.
Users browsing this forum: No registered users and 28 guests
