Install/PackageAware Trial - Crashes
Henry
Postby Henry » Wed Apr 20, 2005 8:43 am
I am trying to trial you Package aware to re-package some old applications, I can run the 'Before' and 'After' Scan and it creates all the files and tells me I can use InstallAware to package it.
When I open the package created by PackageAware in InstallAware it just crashes and gives a 'Not Responding' Error in Task manager. I left it for 30mins to make sure its not super-slow loading (which I doubted as its an ample spec PC)
Its a clean Win XP with SP2 install btw.
Any ideas?
-Henry
sinan
Postby sinan » Wed Apr 20, 2005 5:08 pm
If you are repackaging very large setups (they can install a very large amount of files, and/or create a very large amount of registry keys), this can occur. What is the setup you are trying to capture?
Guest
Postby Guest » Thu Apr 21, 2005 3:00 am
It is actually a very small package. 1.08MB of files, and no more than 50 reg keys.
Not a complex application either, propably as basic installation as you can get as its just a simple number cruncher.
sinan
Postby sinan » Thu Apr 21, 2005 3:26 am
If you can let me know where to get the app, I'd be glad to give it a try.
Henry
Postby Henry » Thu Apr 21, 2005 9:34 am
Cracked it, PackageAware was trying to add the 500MB hibernation file!
:roll:
sinan
Postby sinan » Thu Apr 21, 2005 5:39 pm
Oh - wow! Thanks for reporting this, I'll add those files to the default exclusion list.
Return to “Non-Technical”
Users browsing this forum: No registered users and 111 guests
