Writing to web.config file
adeid
Post by adeid »
Please can you tell me how I can write to web.config file of my web application during installation? I want to add some configuration settings to this file during installation.
Thank you.
You can use the Write to Text File command.
adeid
Post by adeid »
Please can I get script on how to use "Write to Text File command" to acomplish this?
Please drag-drop or type to insert the Write to Text File command into your setup script, and press F1 while the window is showing to get command help.
adeid
Post by adeid »
The "Write Text File Command" can not help in this situation because it can only write to the begining or end of a file. But I need to write to the "application settings" section of a web.config file. Any suggestion?
Gizm0
Post by Gizm0 »
Multiple Write Text Commands! :)
First call to write the start part of file, then the application block, then the rest of it.
Panagiotis Kefalidis
Software Design Team Lead
Also check the EditFile plug-in, available for free on this forum.
