Installing a separat file
jamesblast
Post by jamesblast »
we are thinking of buying installaware, but there is one question remaining.
We want to put a custom file along with the installpackage ie on a CD.
The installer sould then install this file into the installationdir.
How is that possible with installaware?
The problems are: the file is NOT included into the msi/installer -file. It is placed in the same dir as the installfile.
Thank you.
Regards,
james
Hi James,
Quite easily done.
Just use the Copy/Move Local Files command, and read the file from $SFXPATH$\\filename, or if $SFXPATH$ is empty from $EXEDIR$\\filename. And that will take care of it for you.
