advert resolution
jweksej
advert resolution
Postby jweksej » Thu Oct 26, 2006 2:56 pm
one of theme progress dialog contains object where advert is displayed. I would like to prepare advert which will exactly fit the object and will be displayed without margins and scroll bars. I started from object resolution and after few iterations (time consuming) I did not obtain the result. Please let me know how to calculate the resolution starting from object size to avoid this 'error and trial' loop.
Postby MichaelNesmith » Thu Oct 26, 2006 5:32 pm
What you can do is copy the advert files directly to the <InstallAware folder>\\interop\\templates folder.
Then re-start the dialog editor after each change. Will be faster this way :)
Users browsing this forum: Google [Bot] and 27 guests
