I am having a problem accessing a file i have included via "File Bag" during a "Run Program" call.
The program i am trying to run is OSQL (MS SQL Server).
Msg 3201, Level 16, State 2, Server SERVER, Line 1
Cannot open backup device 'C:\\DOCUME~1\\MyUserAccount\\LOCALS~1\\Temp\\mia23.tmp\\data\\Microsoft .NET Framework 2.0\\mFileBagIDE.dll\\bag\\Database.bak'. Operating system error 5(Access is denied.).
Msg 3013, Level 16, State 1, Server SERVER, Line 1
RESTORE DATABASE is terminating abnormally.
When i go out to inspect that file and look at the security rights on it, (while the setup package is running)
"MyUserAccount" shows up in the list with the following grants:
[Full Control, Modify, Read & Execute, Read, Write]
"MyUserAccount" is in the administrators group on this machine.
I am using InstallAware Studio version 6.0.6 (SP03).
I've tried this with both "Run Program" and "Run Program As"
I looked at Windows Task Manager while setup was running and saw OSQL running as "MyUserAccount"
When i use "Run Program", it should be running as the currently logged in user account, right?
any idea what i'm doing wrong?
thanks,
drew
File Bag Permissions issue
It's a stupid behavior from SQL Server.. Even if you have an account named "test" on both machines, they have a different GUID, and you get an error. Best practice is to add the .bak file with "Everyone" permission (Read/write) etc and protect it with a Media password, so noone can restore it without a password. Execute the rest of the steps as you do now and it will work..
Panagiotis Kefalidis
Software Design Team Lead
