Need Help on Terminate Programe command
Raj
Postby Raj » Wed Nov 01, 2006 9:20 am
I have used "Run Program" Command to run program after installation completed it's working fine. But now i want stop that running program at uninstallation before drop database script. So I am using "Terminate program". But it is not terminating that program at uninstallation.
This "Terminate Program" command works fine when i wants to terminate a program having name such as "Word Web" or "Fifa 99" etc. but my running program is simmilar to MSSQL Server i.e it's an engine, it's tool tip shows "SERVICE_RUNNING/LOCALHOST/RFIDService" So how can I stop running this engin at uninstallation time.
For "Run Program" I have used name for above launch.exe but when I used same name launch.exe or launch only with "Terminate Program" command then also it's not working
Please help me regarding this issue
Raj
:cry:
John Smith
Terminal Program
Postby John Smith » Mon Nov 06, 2006 3:59 am
Hey got simmilar problem of terminating program at uninstallation. I need to terminate engin e.x. SQL Server engine at uninstallation time. I have used "Terminate Program" Command but it's not working as per my liking. So please help me if u know the solution
John
Postby MichaelNesmith » Mon Nov 06, 2006 4:12 am
This command is meant for programs running interactively on the end-user desktop, as identified by their window class and caption text.
John Smith
Terminal Program
Postby John Smith » Mon Nov 06, 2006 4:25 am
So what can I do to stop that engin? Is there is another way should I try?
John Smith
Terminal Program
Postby John Smith » Mon Nov 06, 2006 5:08 am
The engin which I wana terminate at uninstallation it's running on my desktop only. So which command or method should I used?
John
Gizm0
Postby Gizm0 » Mon Nov 06, 2006 5:08 am
If it is a service you can stop it by using service control.
Panagiotis Kefalidis
Software Design Team Lead
John Smith
Terminal Program
Postby John Smith » Mon Nov 06, 2006 6:26 am
It's not a service, So when used control service command then also it's not working. when I used Run Program command then it is display in quick launch window. For terminating that application, I give "Terminate Program" command but still didnt find desire result. I have successfuly Terminate that program which toll-tip is like "ProcessPrc", "WordWeb","Volume". But my application display tool-tip like "Running-Desktop1\\MsSQLServer."
So please, Guide me regarding same.
Thanks for reading!!!!!!!!!1
John
Users browsing this forum: No registered users and 46 guests
