Oracle client and network components not found
ekekakos
Post by ekekakos »
Hello, I am testing the InstallAware and until now I found it excellent. I am using VB.NET and making programs which are connected to our Oracle database. I try to install one in a PC and when I tried to connect to the database I received the following error:
Oracle client and networking components were not foundThese componetnts are supplied by the Oracle Coorparation andare part of the Oracle version 7.3.3 and later. This program will not run until the installation of these.
I have an installation file but my question is if I can do it automatically through a pre check of the InstallAware.
Thanks in advance
Gizm0
Post by Gizm0 »
Maybe i'm missing something, but you got this message when you where trying to do what?Run a script against the Oracle Database using the Oracle Plugin?After the installation of your client?
Give us some more info to help you!
Panagiotis Kefalidis
Software Design Team Lead
ekekakos
Post by ekekakos »
I have installed my application in a pc without the client and when I run the program and I am trying to connect to the oracle db in order to run a script I have the above message. I know that the oracle client is missing but how I can do a preriquisite in InstallAware like Framework2 or Windows Installer etc. Namely when I m installing my aplication through InstallAware, this will detect if the oracle client is missing and if yes install it from the cd.
Unfortunately, there is not a pre-built Oracle runtime provided with InstallAware. However, you can read this whitepaper:
for a description of the simple process to create your own. Additionally, InstallAware supports Oracle .Net which lets you connect to Oracle servers without requiring any client software on the machine!
So just choose the most versatile option for yourself...
greenstone
Post by greenstone »
Hi Michael,
regarding your statement:
Would you be ale to clarify?
From my understanding, using the Microsoft or Oracle .Net driver requires the Oracle network component installed on the machine (maybe the easiest way to get this network component installed is to install Oracle client is installed).
Maybe Installaware written or licensed a library for connecting on the Oracle network?
Do I remember correctly that InstallAware uses the OLE-DB .NET provider? Here's a link describing the requirements for OLE-DB to connect to Oracle http://support.microsoft.com/kb/q244661/
I'm considering using InstallAware for our product installer (including running oracle scripts), so understanding the limitations on this is important to how we go on this.
Thanks!
greenstone
Hi Michael,
Thanks!
Alex_Ronquillo
Post by Alex_Ronquillo »
The Oracle Database plug-in included with IA is capable of connect to an Oracle database without any other client software being installed in the user's computer. You just need the plug-in included in your project and that will do it.
Alejandro Ronquillo
greenstone
Hi Alex,
Thanks for the fast reply.
I was able to connect to SQL Server (using the installed sample in the "Samples/SQLServer Connection" directory) via the InstallAware installer, but have not been successful with Oracle. The error I am getting in a messagebox is:
"The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2728."
Any thoughts on what might be the issue?
Do you have a sample project for connecting to Oracle?
Thanks!
Alex_Ronquillo
Let me do one and I'll post it.
Alejandro Ronquillo
greenstone
That would be great. It will help us with our evaluation of Installaware.
Tiago
Post by Tiago »
How can I detect if either Oracle Client or ODAC are present in the end-user machine?
[b]Tiago Rocha[/b]
[i]Product Technology[/i]
www.ppi-multitask.com.br
neillans
Post by neillans »
Hi Tiago,
You will need to extract the install GUID from an Oracle Client's install, then write a script to check for the existance of this GUID being registered with the MSI engine.
For more information, have a look at the Crystal Reports or any of the other runtimes.
Andy Neillans
Tiago
Post by Tiago »
Hi Neillans!
How can I extract this GUID?
Thanks in advance!
[b]Tiago Rocha[/b]
neillans
Post by neillans »
You will need to open the MSI using the ORCA tool from Microsoft, and you should fine the product GUID there.
Good luck :)
Andy Neillans
Tiago
Post by Tiago »
Hmmm... great! I'll try to do that!
But what if I'm installing another application installer which doesn't use the MSI format?
Is there any other alternative?
Thank you, Neillans!
[b]Tiago Rocha[/b]
