I am testing on Vista RC1.
I run the InstallAware generated install. The vista UAC asks if I want to run the setup progam (my app isn't signed yet). I click to allow it. My setup proceeds correctly and installs as it should. It reaches the Finish dialog, and I select the "Run Title" check box, and then press "Finish". My application starts up. I create a document, and save it to disk, and exit the application.
Later I start my application from the Start Menu. I open the previous document, make a change, and try and save it. Error! It says I don't have permission to overwrite the file.
I'm guessing that my application is at "administrator" privilege when it is installing and launched. Later when I run the app, I'm at user level, and can't overwrite the file.
Have you heard of this? Is there anything I can do when launching the application from the script?
Brad
