Patch -assembly issue
muddasirqdiwai
Postby muddasirqdiwai » Wed Nov 08, 2006 3:32 am
Hi
I created installer that included two assemblies , installer will just install those assemblies in GAC
then i added third asembly into installer
i gave the patch reference for the previous msi (which installed 2 assemblies ) then i build patch patch executed perfectly but it didn't install third assembly
if i repeat whole process by taking normal files as example it work perfectly
patch will install new txt file
i saw difference when i build patch when i build patch for assemblies it miss line (copying assemblies ) but when i build patch installer for txt files it shows those files being copied
can u tell me how can i fix this problem
Users browsing this forum: No registered users and 40 guests
