troubles with extraction 7zip
mikesm
Postby mikesm » Fri Nov 10, 2006 2:22 am
I have exe a 7zip files in the same location (CD-ROM). Sometimes, I have troubles with extraction of web media block. The same build work corect on one PC and don't work correct on the other one. I don't know why? Do you know about any mistake?
Postby MichaelNesmith » Sat Nov 11, 2006 3:17 pm
Check available disk space, free memory, anti-virus software, or other items that might be interfering.
Also when working with optical media, CD's that work on one system might not work on another system. To see if the CD's are the cause of the error, try copying all files to the PC using Windows Explorer to see if the files can actually be read off the physical CD.
mikesm
Postby mikesm » Thu Nov 16, 2006 4:30 am
I tried to copy CD to local disk. There is no other software except WXP. And result? The same. Troubles with extraction of web media block.
Postby MichaelNesmith » Fri Nov 17, 2006 10:05 am
So you're either running out of memory, disk space, or you have specified illegal extraction parameters (ex: incorrect password, bad file paths, etc)
Users browsing this forum: No registered users and 40 guests
