atekant
Post
by atekant »
I just downloaded the new build, and installed it.
The about box still says sp3.102006
The installer file version says: 6.07.3797.2006
Isn't the about box supposed to say sp3a?
Is there a trick to upgrading properly I don't know about?
(I just ran the new setup, it said it was going to uninstall the old version itself)
Post
by MichaelNesmith »
You probably installed an older version license on top of the new version. Be sure to regenerate and reinstall your license.
atekant
Post
by atekant »
OK, I seem to have missed the regenerate license part.
Now I have sp3.111106
Still doesn't say sp3a. Is that OK?
Post
by MichaelNesmith »
Yup, you got nothing to worry about.
