Instructions to get this update:
a) If you are a trial user, simply re-download the trial edition, and re-install.
b) If you are a licensed user for the current version, re-install the latest trial, then log on to your customer account, re-generate and install your license.
New .NET Framework 3.0 Runtime detection and installation support:
Seamlessly detect and install the new .NET Framework 3.0 as part of your own installation. All prerequisites are handled correctly, and all setup progress is captured and displayed natively. The update mechanism has been implemented as a new InstallAware Application Runtime, with full sources available for editing as include scripts in the IDE.
Free InstallAware Update for .NET Framework 3.0
