MSI Code Drag/Drop Bug
H4nd0
Postby H4nd0 » Tue Nov 14, 2006 5:44 am
When editing your MSI code and you are scrolled along way down in a Media Block (line 250+ for example) and then you attempt to drag a Script Command into the section you are working (eg. a comment) and the line you want to place the Script Command is not fully selected, the MSI code view re-scrolls back to line 1.
The only way I have found around this is to remove focus from the main IA MDI and then drag/drop.
This is irritating to say the least! Please fix.
Postby MichaelNesmith » Tue Nov 14, 2006 11:38 am
Sorry for the inconvenience...but we generally recommend you just TYPE in the editor directly. The drag-drop is a relic from the old versions that did not support direct editing in the IDE, and if you ask me, it should have been taken out already.
Users browsing this forum: No registered users and 47 guests
