Simply by adding the old exe to the patch-reference and add a new file into the file-list.
Then, click on 'build patch' I constantly get the error:
"LABEL statements cannot be nested inside loops/conditionals"
I really have no clue on what is wrong with my code, bacause creating a normal build this message is not shown!?
here's a snippet from my code:
After, the message the label "Maintenance" is selected.
if Variable SILENTMODE not Equals TRUE
wizard loop
Display Dialog: welcome, wait for dialog to return (modal)
[compiler if Variable BUILDMODE not Equals PATCH]
Display Dialog: destination, wait for dialog to return (modal)
[compiler end]
Display Dialog: startinstallation, wait for dialog to return (modal)
GoTo Label: Main Install
<<Code Folding Region>>
[DEFINE REGION: Process (Un)Installation]
label: Maintenance
Comment: Maintenance Install/Uninstall
Set Variable UNINSTALL to YES
MessageBox: $TITLE$ Uninstall, Are you sure you want to uninstall the selected application and all of its components?
if Variable UNINSTALL Equals NO
Terminate Installation
else
Set Variable REMOVE to TRUE
[DEFINE REGION: main installation]
label: Main Install
Comment: Exit Setup if Wizard Loop cancelled
if Variable WIZARD Equals CANCEL
etc.etc.
Ton.
p.s. if more code is required, please tell me. i will post it!
