MS SQL Server & Windows Vista
andrejzr
Postby andrejzr » Mon Nov 20, 2006 3:57 am
When testing my installer on Windows Vista, My MS SQL Server action is not working. I made the same tests with the sample install script ("SQL Server Connection"), it does not work also.
Here are some more details about the environment:
- Windows Vista (RTM)
- SQL Server 2005 Express
- InstallAware 6.07
When running the installation, connection to the database fails.
When running SQL Server Manager or another application, which connects to the database, things are working OK. I am running the setup locally, so remote connections are not used.
Do you think this might be related to Vista, to MS SQL Server plugin, to my install script?
If you have any hint how to further diagnose this, I am willing to do whatever you say.
Thanks in advance
Andrej.
Postby MichaelNesmith » Mon Nov 20, 2006 6:13 am
AFAIK, you need to have SQL 2005 with Service Pack 2, which is not even released yet, for correct SQL Server Express functionality on Vista.
andrejzr
Postby andrejzr » Mon Nov 20, 2006 9:22 am
Hello Michael,
Thank you for the quick answer. I will try with SQL Express SP2 CTP version.
But, when I use another SQL Server from the Vista machine, this should work fine, shouldn't it? The IA's MS SQL Server actions does not want to connect, but when running another application (using Delphi ADO access), the connection succedes without any problem.
Do you see any way how to find a reason, why the installer's action fails? I know that Vista is not out there yet, but we are now focusing on the product to be ready for it, and we will also certify it later for Vista.
Your support is highly appreaciated.
Andrej
Postby MichaelNesmith » Mon Nov 20, 2006 10:32 am
It should definitely succeed in connection attempts - I think it might be related to other SQL connection issues frequently reported and resolved on this forum. Do let us know if there is a Vista specific issue that you cannot resolve and step-by-step instructions to reproduce.
tltaylor76
Issue Remains
Postby tltaylor76 » Thu Feb 15, 2007 12:32 pm
I am running Windows Vista and have installed the SQL Server Express SP2 CTP. Regardless of how you attempt to authenticate, it never will when SQL Server Express is installed on the Vista machine.
I CAN however, authenticate through code with no problem. The issue only seems to come through the InstallAware setup when authenticating SQL Server.
Just FYI, if you run the installation on the Vista machine and attempt to authenticate a SQL Server NOT installed on the Vista machine, it will work.
To reproduce do the following:
1. Install SQL Server Express SP1 or SP2 CTP on the Windows Vista machine.
2. Within an InstallAware installation, attempt to authenticate SQL Server Express using the MS SQL Server Script execution line providing nothing but the authentication properties and GO in the code.
I have tested this over and over again before posting just to make sure that there was some type of issue. The issue could be me :) and any direction would be appreciated. Thanks.
Trent L. Taylor
Sr. Software Developer
StrataFrame Application Framework
www.strataframe.net
Postby MichaelNesmith » Fri Feb 16, 2007 7:54 am
You may need to open up a firewall port or two - as InstallAware connects through the network directly.
You can also try to use the Alternate SQL Server plug-in.
Please keep in mind that we do not support beta products. If this issue is not resolved when SQL Server Express SP2 is officially released, you can expect to see a fix very quickly. Until then, please tell us if opening a firewall port works (described on this forum), and if Alternate SQL Server plug-in works.
tltaylor76
Postby tltaylor76 » Fri Feb 16, 2007 8:06 am
The firewall is disabled. In fact, I have firewalls disabled through a group policy on the network to prevent this type of thing from happening. You mentioned an alternate method. I guess I do not know about this...what is the alternate method?
Trent L. Taylor
www.strataframe.net
Postby MichaelNesmith » Fri Feb 16, 2007 8:09 am
Download and install and update your scripts to use the new Alternate SQL Server plug-in available free from the Plug-Ins section of this forum.
neillans
Postby neillans » Fri Feb 23, 2007 7:09 am
You may also need to check the configuration of SQL Server; specifically, check the Agent and Browser are running.
The browser is needed for network connectivity, even if the protocols are enabled.
Andy
tltaylor76
Postby tltaylor76 » Fri Feb 23, 2007 10:21 am
Thanks for your input, but this is unrelated to the problem. The SQL Servers is located, can be pinged, is setup to accept TCP/IP connections on port 1433, etc... and InstallAware can see the SQL servers and even returns the SQL Server in a list of available servers....it just cannot be authenticated. I have confirmed that this is definitely an issue within InstallAware at the moment on a Vista machine. I wrote a .NET installer class work around to get around the issue at the moment.
Trent L. Taylor
www.strataframe.net
neillans
Postby neillans » Fri Feb 23, 2007 10:28 am
Hmm.
I've just checked the SQL plugin in IA 6.24, and had no problems connecting a SQL Server 2005 Enterprise server, installed as a named instance - either locally or remotely - using standard authentication as you describe.
However, I should stress, the method of connection that IA uses does require network connectivity.
Have you updated to a more recent build? If so, and the problem persists, I would like to work with you to narrow this down and get it resolved.
Andy Neillans
RobertKozak
Postby RobertKozak » Mon May 21, 2007 7:05 pm
Andy,
I am having the same problem. No matter what I try Microsoft SQL Server Script will not authenticate against a Vista Client. It works great with no problems in XP.
Detect MS SQL Instances does work in Vista. It will return the ServerName and Instance.
Do you have any more information on this?
Also on a related note Detect MS SQL Instances will not return the Instance name on Windows Server 2003.
All of these test were run against MSDE and SQL Server 2005 Express.
-- Robert
tltaylor76
Never been resolved
Postby tltaylor76 » Tue May 22, 2007 8:54 am
This issue has never been resolved and has been a point of frustration ever since I posted on this thread back in February. As of yet there has been no resolution to my knowledge and the issue still exists. This issue has been confirmed by some other developers that I know that are using InstallAware.
Trent L. Taylor
www.strataframe.net
RobertKozak
Postby RobertKozak » Tue May 22, 2007 12:10 pm
Trent,
You mentioned earlier that you had a .net installer class that worked. Can you PM the code or details?
-- Robert
tltaylor76
Workaround
Postby tltaylor76 » Tue May 22, 2007 1:21 pm
Actually I had to quit using the .NET Installer class and move entirely over to a command line EXE which does the same thing. InstallAware does not reliably execute the .NET installer classes with their InstallUtil app which caused a lot of frustration and support issues in the field. However, the DO reliably execute an EXE....so I moved all of the Installer Class code into an EXE which accepts a number of different parms and it was ultimately cleaner anyway because InstallAware does not allow more than one Installer class per assembly.
If you are familiar with .NET I just called the EXE and wrote the results to a registry value that InstallAware could then read.
Dim loConn As New SQLConnection(YourConnectionString)
Dim llReturn As Boolean = True
Try
loConn.Open()
loConn.Close()
Catch ex As Exception
llReturn = False
EndTry
'-- Determine the results and write the according registry values
If llReturn Then
'-- Just write to the users registry in the Software key somewhere that
' that the test succeeded
Else
' the test failed
End If
Note: To pass over the form information that was captured within a custom InstallAware form, I wrote to an INI file because the registry values are not committed until Apply Install command. So I read in the INI values to create the connection string and then wrote the results back to a registry value so that InstallAware could read those values and then do something with it.
Trent L. Taylor
www.strataframe.net
Users browsing this forum: Baidu [Spider] and 116 guests
