Sub Component selection
IntelliServ
Postby IntelliServ » Tue Nov 21, 2006 5:38 pm
I have an installer in which I want to make a logical grouping of utilities as components (as if they were in folders). To do this I was thinking about making the utilities sub-components of empty components (i.e. the component "testing" would not install anything but its subcomponents would). I've noticed that to enable "Entire feature will be installed..." on the categories I have to define the category as a component. However, doing that enables "Will be installed..." on the category, without selecting a sub component. I would like to allow the user to select individual sub components or choose the select all option on categories, but not be able to select a category without selecting at least one sub component.
I realize that my request may be difficult to understand so here are some truth tables:
Actual (only sub components defined):
    Can select/unselect individual sub components.
    Can Not select/unselect individual parent component.
    Can Not select all from parent component.
    Can Not unselect all from parent component.
Actual (sub and parent components defined):
    Can select/unselect individual parent component.
    Can select all from parent component.
    Can unselect all from parent component.
Desired:
    Can select/unselect individual components.
Users browsing this forum: No registered users and 43 guests
