I need to remove the Modify Available Option when Un Install, since there are no features. All files are needed for the installation.
If the user clicks that options he/she gets a screen with no options.
Doron
How to remove the Modify Available Option
Various ways:
a) Use the dialog editor to remove the radio button, and then go ahead and set the MODIFY variable to FALSE and REMOVE variable to TRUE in your MSIcode so the correct defaults show on the dialog.
OR
b) Use the Project Wizard to create a new project, and select the "uninstall only" option at the dialogs screen. Then, copy-paste the code back into your own project so your project behaves the same way.
OR
c) Just edit the MSIcode directly using a combination of the above two methods to implement the desired effect.
OR
OR
