Install merge modules as a feature
I would like to offer two options to users during the install, a 'minimum' and a 'full' install. The minimum install is the main program. The full install would be the main program plus 3 merge modules. How can I install the merge modules only if the 'full' option is selected? I'm assuming that the merge modules would be associated with a feature, but I don't see the link between the feature and its associated files.
Sorry, this is not possible - merge modules are not part of MSIcode scripting, so it is not possible to conditionalize their execution. What you can try, however, is to create an empty setup just with the merge module, and install that when the features are selected.
