I have two installables:
1) An Exe file
2) An MSI file
Is there a way to combine these two files into a single installable using InstallAware, if yes, how can this be done?
And also, I would like to install .exe file before .msi file if these two can be combined into one installable.
Thanks in Advance,
Swadeep
Combining two executables into one
1) Add both files to your setup as support files (using Project Manager).
2) Run the EXE using Run Program and run the MSI using (Un)Install MSI Setup. Both of these commands need to be inserted in the MSIcode view (ALT+C).
Hi Michael,
Thanks for your reply.
What are the parameters I need to pass to Install/Remove MSI Package[]?
Please find attached the document containing the window I am getting when I click on the (Un)Install MSI Setup, under which tab do I need to provide my msi details.
And I am also looking for a single executable file as the output which can be distributed to the users so that they can install the application (which inturn install exe first and then the msi next).
Thanks in Advance,
Swadeep
<a href="files/121920061546/InstallAware.doc">InstallAware.doc
Thanks in Advance,
Swadeep
MichaelNesmith wrote:1) Add both files to your setup as support files (using Project Manager).
The parameters really depend on your MSI package. At a minimum you want to click the Install button and also set the path to your MSI file using the form $SUPPORTDIR$\\msifile.msi.
Combining two installables into one
Hi Michael,
I am using the below command, is it correct or am I doing a mistake?
Install/Remove MSI Package [$SUPPORTDIR$\\MSIFile.msi]
I am able to trigger the installation of the exe but I am unable to trigger the installation of this MSIFile.msi.
Swadeep
Swadeep
You forgot to click the Install button.
I didnt forget to click the install button.
I get the following command if I directly click the install button
Install/Remove MSI Package [ADDLOCAL=ALL]. After this step where do I need to provide details of my MSIFile.msi
If I provide $SUPPORTDIR$\\MSIFile.msi in the Install/Remove MSI Package dialog I get Install/Remove MSI Package [$SUPPORTDIR$\\MSIFile.msi] on click on Install button
Please correct me
Please correct me
Um...I think you need to do both
Users browsing this forum: No registered users and 150 guests
