Plug-in installation
Plug-ins
Post by Plug-ins »
I am in the process of evaluating the sofware. How do I install the the plug-ins and where do I get them from. I explored the Plug-in folder and only the Flash plug-in I installed was located in there. I am particulary interested in the .NET Framework and those listed in the Plug-in listing.
sinan
Post by sinan »
If you see them in the plug-in listing, then they are already installed. When you install InstallAware, you get a good number of plug-ins. You may also install additional plug-ins from third party sources to add more behavior, but if you are seeing an item in the plug-in listing, its already installed.
Create a .NET project or use the Project Wizard and check the .NET option to create setups that install .NET.
