I've created a setup, installed it in a vmware machine (web install).
Then I've created a patch for the first installation.
The scheduler detects the patch correctly, downloads it but then I get a blank dos box that simply hangs.
That's it, nothing else happens.
What's wrong?
Dominique.
Patching hangs
Did you try to run the patch file stand-alone to see what happens then?
Also, try to run the updater in debug mode inside the IDE, if the patch works fine stand-alone. Then you can further troubleshoot the issue in case its in the updater.
Users browsing this forum: No registered users and 122 guests
