This function is to clever and simplifies double slashes...
I need to place: name\\\\name and it always places name\\name.
Does not matter how many \\\\\\\\ I will place between names...
Help!
Edit INI file problem
This is to eliminate the manual labor of replacing double-backslashes across your setup.
I think there was another post on this forum which described how to work around this issue. There was a sequence which worked - please try to find it, a search should reveal it.
