Uninstall Question
owen
Uninstall Question
Post by owen »
Is it ok to perform an action after Apply Uninstall is called?
Specifically I am calling Apply Uninstall which stops and deletes the service I installed previously and then I call Delete Files Recursively to delete the installation folder, but I need to do it after the service is stopped so the program will release all open handles on the files I want to delete.
Thanks!
Sure. Delete Recursive is not an MSI command. Therefore, it executes immediately and has no dependency on Apply (Un)Install.
