hi,
we want to buy installaware. i've tested it, but i've got a question:
i create a setup. the setup creates a textfile on my desktop. in the textfile is the word "hello". i open the textfile and write "hello1234" in it. i start the setup again, but the changed textfile won't be overwritten, because in the file is the changed text "hello1234" and not "hello". how can i realize that the file actually will be overwritten?
overwrite existing changed file
If the file has changed, this will be detected by either a version change, or a date change. In your case the date is probably newer, so the overwrite is not occuring.
You could of course manually delete critical files before calling Apply Install, this way ensuring their original copies will be installed - try Delete Files Recursive.
Users browsing this forum: Majestic-12 [Bot] and 167 guests
