'Create Share' on Xp
jweksej
Postby jweksej » Mon Dec 18, 2006 10:46 am
'Create Share' on Xp does not work when 'Simple File Sharing' option (explorer 'Tools->FolderOptions->View' dialog) is enabled.
How to get current status of this SFS and how to change it from IA script level? I've found some info - shell32 allows to change it but I've failed on looking which function is responsible for it. Do someone know how to do it?
Any help appreciated
regards
Jarek
PetSo
Postby PetSo » Tue Dec 19, 2006 3:30 am
Wouldn't it work to run a commandline similar to:
'net share mytemp=c:\\tmp /REMARK:"MyTemp"'
Instead of changing the settings on a users computer?
To get info on more commandline options for 'net share' type 'net help share' on the commandline.
/PeterS
jweksej
Postby jweksej » Tue Dec 19, 2006 4:35 am
No, it doesn't works. For security reasons MS disabled this feature (simple file sharing) in WinXp. It is easy to enable it from explorer GUI, but I would like to do it from IA script level.
PetSo
Postby PetSo » Tue Dec 19, 2006 5:11 am
Yes I can see that you would like the feature to work in IA, I was just trying to give you an option while you wait for them to fix it.
FWIW
I tried setting the SFS to off and to me it seemed the 'net' commandline worked equally well to create a share wether SFS was on or off.
A quick search with google seems to indicate that the only way to enable/disable SFS is with that checkbox in explorer.
To check if it is enabled you can read
HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Control\\Lsa\\ForceGuest
If it is 1 then SFS is enabled.
/PeterS
Users browsing this forum: Majestic-12 [Bot] and 130 guests
