Setup problem.
hsiao36941
Setup problem.
Postby hsiao36941 » Thu Dec 21, 2006 2:44 am
I created a setup and try it, but I got a error message like below image:
Please tell me what is problem? and what to do now?
Thank's
Hsiao
Gizm0
Postby Gizm0 » Thu Dec 21, 2006 6:26 am
Try rebuilding the setup and try again, make sure you have proper access to the folder you try to install, that all web media blocks exist and they are not corrupted and that your setup file is downloaded correctly.
Panagiotis Kefalidis
Software Design Team Lead
Postby CandiceJones » Thu Dec 21, 2006 9:21 am
A simple search on the MSDN Help Library or the Platform SDK Help Library for "windows installer error 2343" provides the following information:
2343 Specified path is empty.
So it probably means one of your Install Files commands or Create Directory commands have an empty target path. Just fix that and the error will go away.
hsiao36941
Postby hsiao36941 » Thu Dec 21, 2006 10:55 pm
It to solve after remove ODBC driver, but I need ODBC driver, how to do it?
CandiceJones wrote:A simple search on the MSDN Help Library or the Platform SDK Help Library for "windows installer error 2343" provides the following information:
Postby CandiceJones » Fri Dec 22, 2006 9:06 am
So, it seems you did not specify the target path in the ODBC command, then. Edit the ODBC command again, and be sure to specify the target path.
hsiao369
Another problem
Postby hsiao369 » Wed Dec 27, 2006 8:31 pm
When build project, I get a error message:
Error during build: Access violation at address 004EA95D in module 'miaa.exe'. Read of address 00000010
How to solve?
Thank's
hsiao369
One more question
Postby hsiao369 » Thu Dec 28, 2006 1:11 am
Lunch the install pagkage, after copy files, another error message is:
Translate to english is mean "Can not write the value FIFRxxxxx to register UNKNOWN\\xxxxxxxxxxxx. Please check your right to access the register.
Postby CandiceJones » Thu Dec 28, 2006 12:02 pm
Make sure you specified a valid version number for your product...the IDE is helpful in that it will warn you with a message balloon (assuming you kept them turned on) when an invalid version is entered.
hsiao369
Postby hsiao369 » Tue Jan 02, 2007 10:16 pm
It's not this reason.
After divide files (*.*) into 2 or 3 part , and un-check subfolders , it's done.
CandiceJones wrote:Make sure you specified a valid version number for your product...the IDE is helpful in that it will warn you with a message balloon (assuming you kept them turned on) when an invalid version is entered.
Postby CandiceJones » Wed Jan 03, 2007 9:19 am
In that case, upgrading to the latest version will also resolve this issue for you, you were probably experiencing issues with web media block path depths which has been resolved.
Return to “Non-Technical”
Users browsing this forum: No registered users and 48 guests
